sync software for nsa 325v2
cchristos
i would like to know if you could suggest me a fast software to sync my files to the nsa325 v2.
at the moment i use memeo backup but it takes ages to sync
#NAS_Dec_2018
#NAS_Dec_2018
@cchristos
Is your system Windows? If it is Windows then there is the internal robocopy program, maybe you can try this.
How-to use Robocopy to synchronize files between two systems from Google:
http://burpee.smccme.edu/studenthowtos/robocopy.htm
i would like a program cloud station backup from synology for a windows 10 pc. at the moment i am trying Syncback and goodsync.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
