Can't access router settings with VGM1312-B10D
panospc
panospc Posts: 2 image  Freshman Member
edited December 2018 in Smart Home Product
I have updated my VGM1312-B10D to the latest VMG1312-B10D_5.13(AAXA.8)C0 firmware
  • Restart the router
  • Reset the router
  • Connect with WiFi and ethernet cable
  • Connect from my phone
  • Different browsers
  • Connect from my pc by using a live linux distro
Is there any way to flash a firmware without access to web interface?
#CPE_Dec_2018
  • panospc
    Bellow is the screenshot, as you can see, only the title and the light gray background is visible.
    Internet worked well until the hard reset, now I can't enter settings to setup my internet connection.
    Here is a screenshot of the source code of the page
  • AAAAL
    AAAAL Posts: 125 image  Ally Member
    Hi panospc,
    By observing your screenshot, I  think the web page had a response, you can clear the browser cache first and try this URL: http://192.168.1.1/login
  • tommy
    tommy Posts: 2 image  Freshman Member
    hi,
    i have a NSW ZyXEL GS1900-24E and also at me it is not working to reach the web interface. i even didnt reach it one time.
    Any help?
    I tried everything which was mentioned above in this thread.
    Tommy
  • newBie_
    newBie_ Posts: 15 image  Freshman Member
     Hi @tommy,
    Looks to me that you haven't found out your GS1900 IP right?
    AS I've read in the other discussion, you can use ZON utility to discover the IP of the device but must be in the same subnet. And I've tried it you can also use ZON to access the web interface.
    Give it a try.
    Peace!
  • Zyxel_Lucious
    Zyxel_Lucious Posts: 283 image  Zyxel Employee
    Zyxel Certified Network Engineer Level 2 - Switch Zyxel Certified Network Engineer Level 2 - Nebula Zyxel Certified Network Engineer Level 1 - Nebula 25 Answers
    edited January 2019
    Hi @tommy,
    Due to you created another discussion in regards of your question about GS1900-24E.
    We've provided the answer for you in that thread.
    Kindly have a look and let us know if any further question, thanks!
    Sincerely,
    Zyxel_Lucious
