How to switch of the NAS 326
foxiwastl
foxiwastl Posts: 5 image  Freshman Member
edited December 2018 in Personal Cloud Storage
I tried several times to use button for starting the NAS but in vain.
#NAS_Dec_2018
  • Ijnrsi
    Ijnrsi Posts: 254 image  Master Member
    Try press the power button and hold it till you hear 1 beep, then to release the button, the NAS326 will start the shutdown program.
    With 2 beeps, then release the button, NAS326 will be forced shutdown without data saved.
  • foxiwastl
    It should read switch off!
  • Ijnrsi
    Hi @foxiwastl
    So you want to shutdown NAS326? Or power on the device?
  • foxiwastl
  • foxiwastl
    I want to shutdown the NAS 326.
    Thks in advance!!
  • Ijnrsi
  • foxiwastl
    Great, thks a lot!!!!!!
