Folder will not delete
Wullie1320
I have a 1TB drive and just put in a 160GB drive. I have deleted a folder share on the 1TB drive and created the same folder name on the 160Gb drive but the Folder on the 1TB drive will not delete. I have used the NAS starter utillity, went into administration, then shares and deleted the share, but the folder still remains. how can I remove the folder on the 1TB Drive?
#NAS_Dec_2018
#NAS_Dec_2018
Do you have screen that we can see the problem?
Check your share folder privilege, if the folder is under / as the top folder, then it only can be deleted thgough web GUI.
- 441 Beta Program
- 292 Service & License
