Download doesn't work NSA 310
BADMOPAR
BADMOPAR Posts: 4 image  Freshman Member
edited December 2018 in Personal Cloud Storage
Download doesn't work on my NSA 310 from yesterday. The only problem I can found is that my NAS Can not set upnp port mapping. Is there something I can do?
#NAS_Dec_2018
  • Wiasouda
    Wiasouda Posts: 156 image  Master Member
    With download server function and torrent? Try other torrent file to check.
  • BADMOPAR
    I did it already and nothing happens.
  • Wiasouda
    Did you do any specific thing/setting on your NSA310?
    If you could not remember, try reset to default by pressing reset button.
    Reset would not effect your data.
  • BADMOPAR
    No, I didn't. I was trying to download newest part of my favorite TV series. Previous download working well. Now I could try reset my nas, but I have injured my knee today and my NSA 310 is on top of the kitchen cabinet.
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    It is possible to perform a factory reset without physical access. First open the Telnet backdoor, login as root over telnet, and execute
    /usr/local/btn/reset_and_reboot.sh
  • BADMOPAR
    Problem solved. My ISP has changed main gateway address without letting me know. Thanks for your assistance.
