NAS326 Power On/Off Schedule is not working
nas326emin
nas326emin Posts: 5 image  Freshman Member
edited December 2018 in Personal Cloud Storage
Nas326 device does not not poer on-off as scheduled and keeps on his state. How can I solve thid problem?
#NAS_Dec_2018
  • Wiasouda
    Wiasouda Posts: 156 image  Master Member
    What is your firmware version?
    The release note mentioned the V5.21(AAZF.3)C0 release was included the power schedule problem.
    ftp://ftp2.zyxel.com/NAS326/firmware/521AAZF3C0.pdf
    Did you try this version?
  • nas326emin
    My firmware version is V5.21(AAZF.1). I wil ltry the latest version.
  • nas326emin
    I updated firmware but it still does not power off. Do I need to reset to clear installation and reconfigure?
  • Wiasouda
    is it working that you delete the exist schedule and reconfigure the new schedule?
    If no, you can try reset.
  • nas326emin
    reconfiguration and hardware reset did not work
  • Barbarossa
    Barbarossa Posts: 2 image  Freshman Member
    Seventh Anniversary ZCNE Nebula Level 1 Certification - 2019
    When you set configuration,First you should create turn off rule.
    So like this,
  • nas326emin
    Is it written in the document? I havent seen anywhere. I will try this today. O hope it works. This job took a lot of my time.
