Nas326 transmission config
pikehunter
Hello
Transmission saves the downloaded files in the admin folder.
There is a wish to adjust preservation in the new, separate folder, for example share. How to make it?
#NAS_Dec_2018
You should only edit the settings.json file with transmission disabled.
I founded /i-data/.../.PKG/Transmission/.../config/settings.json , but after enable/disable transmission my chages are lost.
Make remote call periodically
transmission-remote nas -w "/i-data/470f7598/video"
it works for me.
- 3K Nebula
- 232 Nebula Ideas
- 6.7K Security
- 684 USG FLEX H Series
- 362 Security Ideas
- 56 Wireless Ideas
- 7.1K Consumer Product
- 309 Service & License
- 504 News and Release
- 96 Security Advisories
- 5.1K FAQ
- 89 About Community
- 111 Security Highlight
