NAS542, how do I add a second hdd in raid 1
bartvd
I started my NAS a few months ago, with just 1 3TB Disk.
Yesterday i recieved a second HDD( gotta love christmas, right) which is also 3TB.
How can i add this disk as a raid1 partition?
#NAS_Dec_2018
#NAS_Dec_2018
You can refer this article: https://kb.zyxel.com/KB/searchArticle!gwsViewDetail.action?articleOid=015007&lang=EN0 -
This was helpfull,
however, i turned off my nas, added the 2nd HHD and restarted the NAS.
The second hdd does not get recognised and I hear like a sort of clicking noise inside the NAS.
Should I wait or is there something i didn't do correctly.
On the NAS Storage manager, I cannot manage my internal storage, and when i click on create it tells me to that : "No disk is available in NAS'.0 -
Does the HDD compatibility with NAS542?
https://www.zyxel.com/products_services/nas540.shtml?t=p#productDetailTab6
Check the HDD is pluging correct and if the same result, type swap HDD1 to slot 2 and HDD2 to slot 1 to make sure the I/O is normal or not.
It is the same drive as the first 1 : a 3TB Toshiba (HDWD130).
The sound in my NAS is now a semi-loud biep sound, when i unplug the drive i can feel it has been turning.
Does this ring a bell somewhere?0 -
NAS powers on, then SATA can trigger the HDD to run, but it seems the HDD is not compatible for NAS as it is not in the official list.
The one beep will ring when boot finished.
Try to test HDD2 in slot 1 to check if NAS can detect the new HDD, if no then you may need to swap a new compatible HDD.0 -
@bartvd : Do you have a way to test that disk outside the NAS? I think it's malfunctioning.it seems the HDD is not compatible for NAS as it is not in the official list.It's not a compatibility list, it's a 'Verified Hard Disk List'. It's a SATA disk, so it should be compatible. ZyXEL tested a small subset of the available harddisks, and published that list. If any of the tested disks turned out to be not compatible, I would have expected a 'Known Incompatible' list also.
Since it is also a toshiba, like my first HDD, it should not be incompatible, I am guessing that is indeed broken. It seems like it is not booting propably, therefor creating the noise.
But how do i test if it is broken? I don't have a desktop where I can put it in for test.0 -
Update, was ale to test HDD on a laptop of a mate, it is indeed broken, thanks for all the help!0
- 438 Beta Program
- 188 Nebula Ideas
- 6.2K Security
- 455 USG FLEX H Series
- 303 Security Ideas
- 81 Switch Ideas
- 279 Service & License
- 436 News and Release
- 91 Security Highlight
