port settings on vmg4381
procadman
I can't seem to access the default ip address: 192.168.1.1.
According to the manual we that is what is needed to run the config manager.
I need to possibly change some port settings to allow better connection to Rockstar online via a PS3.
From Rockstar:
**Please ensure that your NAT type is selected as Open. If your NAT type is Strict, it may be blocking ports used by the game, or it may translate your private port to a non-deterministic public port when sending packets to each different player in your session. Other players will be unable to determine which port to use to make a connection.**
**Check for additional Ports to Forward for GTA Online:** **TCP Ports: 80, 443 UDP Ports: 6672, 61455, 61456, 61457, and 61458**
#CPE_Jan_2019
From Rockstar:
#CPE_Jan_2019
May we know where you get the VMG4381?
If it is a brand new router, the LAN IP should be 192.168.1.1.
You can try to press the reset button for more than 15 seconds to reset the router to factory default.
If you still can't access by 192.168.1.1 after reset to factory default, there might two possibilities.
1. this router loaded the ISP's customized configuration and saved as ROM-D, so the LAN IP is not 192.168.1.1, even you reset it to factory default. You may need to check with the ISP for the login info.
2. the previous owner changed the LAN IP and saved it as ROM-D. You may need to check with the previous owner.1 -
"May we know where you get the VMG4381?"
Supplied by my internet provider (Fuse.net)
- 440 Beta Program
- 292 Service & License
- 4.6K FAQ
