LTE5366 change wan operation mode
stek69
Guys, it's stupid... I take your device to work on 3g/lte networks in order to get Internet, in places where there is no wired Internet. For backup connection via WAN-2, I can't have one. It turns out that such a feature is absolutely useless... But the script using the main wired Internet via WAN-2 (for example PPPoE) and backup LTE sounds much more useful. I assume that the hardware this device will be able to run such a script, and the problem can be solved by updating the web interface of the device. I would really like to see this feature in the firmware update.
#LTE_Dec_2018
#LTE_Dec_2018
Hi stek69,
After internal discussion, we have no plan to change current design for LTE5366. But we will consider your suggestion on developing devices. Sorry to cause this inconvenience.
- 439 Beta Program
- 529 USG FLEX H Series
- 330 Security Ideas
- 49 Wireless Ideas
- 290 Service & License
- 4.6K FAQ
