NAS 540 has lost all data.
Cha
My NAS 540 has lost all data. : / Forum please help!
#NAS_Jan_2019
#NAS_Jan_2019
Mein NAS 540 hat alle Daten verloren. : / Bitte Forum hilf mir! : /0
Is your volume gone? Or HDD can be detected and volume still there, but you can't see the shared folder?
You may describe more about your problem, if possible, that you can provide the sceenshot for your problem.0 -
If possible You could try to provide screenshots from "Storage Manager".
As many as possible...0 -
Hier sehen Sie einige Screenshots von "Storage Manager". Ich habe sie in einer Word-Datei zusammengefügt.0
I think the volumes are ok, but the RAID 5 array is destroyed. What do you think? Can you help me?
Can you enable the ssh server, login over ssh, and post the results of
<div>cat /proc/mdstat</div><div><br></div><div>su</div><div><br></div><div>fdisk -l</div><div><br></div><div>mdadm --examine /dev/sd[abcd]3</div>
~ # cat /proc/mdstatPersonalities : [linear] [raid0] [raid1] [raid10] [raid6] [raid5] [raid4]md1 : active raid1 sdb2[1] sdd2[3] sdc2[2] sda2[4]1998784 blocks super 1.2 [4/4] [UUUU]md0 : active raid1 sda1[0] sdd1[3] sdc1[2] sdb1[1]1997760 blocks super 1.2 [4/4] [UUUU]unused devices: <none>~ # suBusyBox v1.19.4 (2017-05-26 16:43:23 CST) built-in shell (ash)Enter 'help' for a list of built-in commands.~ # fdisk -lDisk /dev/loop0: 153 MiB, 160432128 bytes, 313344 sectorsUnits: sectors of 1 * 512 = 512 bytesSector size (logical/physical): 512 bytes / 512 bytesI/O size (minimum/optimal): 512 bytes / 512 bytesDisk /dev/mtdblock0: 256 KiB, 262144 bytes, 512 sectorsUnits: sectors of 1 * 512 = 512 bytesSector size (logical/physical): 512 bytes / 512 bytesI/O size (minimum/optimal): 512 bytes / 512 bytesDisk /dev/mtdblock1: 512 KiB, 524288 bytes, 1024 sectorsUnits: sectors of 1 * 512 = 512 bytesSector size (logical/physical): 512 bytes / 512 bytesI/O size (minimum/optimal): 512 bytes / 512 bytesDisk /dev/mtdblock2: 256 KiB, 262144 bytes, 512 sectorsUnits: sectors of 1 * 512 = 512 bytesSector size (logical/physical): 512 bytes / 512 bytesI/O size (minimum/optimal): 512 bytes / 512 bytesDisk /dev/mtdblock3: 10 MiB, 10485760 bytes, 20480 sectorsUnits: sectors of 1 * 512 = 512 bytesSector size (logical/physical): 512 bytes / 512 bytesI/O size (minimum/optimal): 512 bytes / 512 bytesDisk /dev/mtdblock4: 10 MiB, 10485760 bytes, 20480 sectorsUnits: sectors of 1 * 512 = 512 bytesSector size (logical/physical): 512 bytes / 512 bytesI/O size (minimum/optimal): 512 bytes / 512 bytesDisk /dev/mtdblock5: 110 MiB, 115343360 bytes, 225280 sectorsUnits: sectors of 1 * 512 = 512 bytesSector size (logical/physical): 512 bytes / 512 bytesI/O size (minimum/optimal): 512 bytes / 512 bytesDisk /dev/mtdblock6: 10 MiB, 10485760 bytes, 20480 sectorsUnits: sectors of 1 * 512 = 512 bytesSector size (logical/physical): 512 bytes / 512 bytesI/O size (minimum/optimal): 512 bytes / 512 bytesDisk /dev/mtdblock7: 110 MiB, 115343360 bytes, 225280 sectorsUnits: sectors of 1 * 512 = 512 bytesSector size (logical/physical): 512 bytes / 512 bytesI/O size (minimum/optimal): 512 bytes / 512 bytesDisk /dev/mtdblock8: 6 MiB, 6291456 bytes, 12288 sectorsUnits: sectors of 1 * 512 = 512 bytesSector size (logical/physical): 512 bytes / 512 bytesI/O size (minimum/optimal): 512 bytes / 512 bytesDisk /dev/sda: 2.7 TiB, 3000592982016 bytes, 5860533168 sectorsUnits: sectors of 1 * 512 = 512 bytesSector size (logical/physical): 512 bytes / 4096 bytesI/O size (minimum/optimal): 4096 bytes / 4096 bytesDisklabel type: gptDisk identifier: F153C90E-A2A3-4EE6-A08E-170D293952D6Device Start End Sectors Size Type/dev/sda1 2048 3999743 3997696 1.9G Linux RAID/dev/sda2 3999744 7999487 3999744 1.9G Linux RAID/dev/sda3 7999488 5860532223 5852532736 2.7T Linux RAIDDisk /dev/sdb: 2.7 TiB, 3000592982016 bytes, 5860533168 sectorsUnits: sectors of 1 * 512 = 512 bytesSector size (logical/physical): 512 bytes / 4096 bytesI/O size (minimum/optimal): 4096 bytes / 4096 bytesDisklabel type: gptDisk identifier: 06A9E941-0131-4C6D-947E-3FA1F4CA085BDevice Start End Sectors Size Type/dev/sdb1 2048 3999743 3997696 1.9G Linux RAID/dev/sdb2 3999744 7999487 3999744 1.9G Linux RAID/dev/sdb3 7999488 5860532223 5852532736 2.7T Linux RAIDDisk /dev/sdd: 2.7 TiB, 3000592982016 bytes, 5860533168 sectorsUnits: sectors of 1 * 512 = 512 bytesSector size (logical/physical): 512 bytes / 4096 bytesI/O size (minimum/optimal): 4096 bytes / 4096 bytesDisklabel type: gptDisk identifier: DBE96E54-F999-4953-A2B2-B0E5E534C386Device Start End Sectors Size Type/dev/sdd1 2048 3999743 3997696 1.9G Linux RAID/dev/sdd2 3999744 7999487 3999744 1.9G Linux RAID/dev/sdd3 7999488 5860532223 5852532736 2.7T Linux RAIDDisk /dev/sdc: 2.7 TiB, 3000592982016 bytes, 5860533168 sectorsUnits: sectors of 1 * 512 = 512 bytesSector size (logical/physical): 512 bytes / 4096 bytesI/O size (minimum/optimal): 4096 bytes / 4096 bytesDisklabel type: gptDisk identifier: 9700C7E5-9A84-4A20-95CE-C10CD7731E88Device Start End Sectors Size Type/dev/sdc1 2048 3999743 3997696 1.9G Linux RAID/dev/sdc2 3999744 7999487 3999744 1.9G Linux RAID/dev/sdc3 7999488 5860532223 5852532736 2.7T Linux RAIDDisk /dev/md0: 1.9 GiB, 2045706240 bytes, 3995520 sectorsUnits: sectors of 1 * 512 = 512 bytesSector size (logical/physical): 512 bytes / 4096 bytesI/O size (minimum/optimal): 4096 bytes / 4096 bytesDisk /dev/md1: 1.9 GiB, 2046754816 bytes, 3997568 sectorsUnits: sectors of 1 * 512 = 512 bytesSector size (logical/physical): 512 bytes / 4096 bytesI/O size (minimum/optimal): 4096 bytes / 4096 bytes~ # mdadm --examine /dev/sd[abcd]30
Hello !Unfortunately I can not interpret that. Maybe you can explain that to me. What is the next step? Thank you for your help.
So far it tells that the raid manager has assembled the system- and swap volume. But it doesn't do anything with the data volume.The 4 disks all have 3 partitions, and a GPT.But the most interesting piece of information is lacking. Does
<div><div>mdadm --examine /dev/sd[abcd]3</div></div><div></div>
really give no output?
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 274 Service & License
- 419 News and Release
- 89 Security Highlight
