NAS 540 has lost all data.
Thanks for your detailed explanation. I entered the command. Here is the result:~ $ mdadm --examine / dev / sd [abcd] 3mdadm: Can not open / dev / sda3: permission deniedmdadm: Can not open / dev / sdb3: permission deniedmdadm: Can not open / dev / sdc3: Permission Deniedmdadm: Can not open / dev / sdd3: permission deniedCan it be that it is related to the fact that the volumes are no longer set up in the Raid 5 array?-------------------------------------------------- ---------------------------------On closer inspection, I found that only the user admins are available. Everyone else is gone.The shared folders are still visible, but have the status: Lost (see pictures in the appendix).Maybe that helps to get a clearer picture of the whole thing.Greetings and thanks0
Is there a way to restore permissions to access all the System Admin folders? Probably before the data belongs to the folder restored?
Ah, sorry. after a new login a new 'su' is needed:
<p>su</p><br><p>mdadm --examine /dev/sd[abcd]3</p><p></p>
On closer inspection, I found that only the user admins are available. Everyone else is gone. The shared folders are still visible, but have the status: Lost (see pictures in the appendix).
The 'shares' are no more than pointers to a directory on the data volume. There is no data volume, so the shares point to nothing. The share database is stored outside the data volume, and so it's still there.0 -
~ # mdadm --examine /dev/sd[abcd]3/dev/sda3:Magic : a92b4efcVersion : 1.2Feature Map : 0x2Array UUID : 04004588:1416a156:bfa20978:5756d5aaName : NAS540:2 (local to host NAS540)Creation Time : Sat Sep 19 19:20:34 2015Raid Level : raid5Raid Devices : 4Avail Dev Size : 5852270592 (2790.58 GiB 2996.36 GB)Array Size : 8778405312 (8371.74 GiB 8989.09 GB)Used Dev Size : 5852270208 (2790.58 GiB 2996.36 GB)Data Offset : 262144 sectorsSuper Offset : 8 sectorsRecovery Offset : 0 sectorsState : cleanDevice UUID : fabc850c:d92b27c4:ef5b37de:ffcafb50Update Time : Fri Dec 21 05:39:03 2018Checksum : 7de6aeb1 - correctEvents : 24293Layout : left-symmetricChunk Size : 64KDevice Role : Active device 0Array State : AAAA ('A' == active, '.' == missing)/dev/sdb3:Magic : a92b4efcVersion : 1.2Feature Map : 0x0Array UUID : 04004588:1416a156:bfa20978:5756d5aaName : NAS540:2 (local to host NAS540)Creation Time : Sat Sep 19 19:20:34 2015Raid Level : raid5Raid Devices : 4Avail Dev Size : 5852270592 (2790.58 GiB 2996.36 GB)Array Size : 8778405888 (8371.74 GiB 8989.09 GB)Data Offset : 262144 sectorsSuper Offset : 8 sectorsState : cleanDevice UUID : 7adf8778:894abce0:2146d412:c64e1c7fUpdate Time : Fri Dec 21 05:48:28 2018Checksum : 693c6190 - correctEvents : 24301Layout : left-symmetricChunk Size : 64KDevice Role : Active device 1Array State : .AAA ('A' == active, '.' == missing)/dev/sdc3:Magic : a92b4efcVersion : 1.2Feature Map : 0x0Array UUID : 04004588:1416a156:bfa20978:5756d5aaName : NAS540:2 (local to host NAS540)Creation Time : Sat Sep 19 19:20:34 2015Raid Level : raid5Raid Devices : 4Avail Dev Size : 5852270592 (2790.58 GiB 2996.36 GB)Array Size : 8778405888 (8371.74 GiB 8989.09 GB)Data Offset : 262144 sectorsSuper Offset : 8 sectorsState : cleanDevice UUID : 1f1b9e0e:9a037d12:13ff3598:3e948926Update Time : Fri Dec 21 05:48:28 2018Checksum : 5de254b0 - correctEvents : 24301Layout : left-symmetricChunk Size : 64KDevice Role : Active device 2Array State : .AAA ('A' == active, '.' == missing)/dev/sdd3:Magic : a92b4efcVersion : 1.2Feature Map : 0x0Array UUID : 04004588:1416a156:bfa20978:5756d5aaName : NAS540:2 (local to host NAS540)Creation Time : Sat Sep 19 19:20:34 2015Raid Level : raid5Raid Devices : 4Avail Dev Size : 5852270592 (2790.58 GiB 2996.36 GB)Array Size : 8778405888 (8371.74 GiB 8989.09 GB)Data Offset : 262144 sectorsSuper Offset : 8 sectorsState : cleanDevice UUID : 8728209d:b362321a:0fbc6cd2:e3926f5dUpdate Time : Fri Dec 21 05:48:28 2018Checksum : 65367cd4 - correctEvents : 24301Layout : left-symmetricChunk Size : 64KDevice Role : Active device 3Array State : .AAA ('A' == active, '.' == missing)0
Sorry, that with the "su", could have thought me too!
Hmm. For some reason sda2 was kicked off the array at Dec 21 05:48:28 2018. The other 3 members seem healthy, so the array should be degraded. Instead it's gone.Can you assemble the array manually (degraded)?
<div>su</div><div><br></div><div>mdadm --assemble /dev/md2 /dev/sd[bcd]3 --run</div>
Hello!here the result of the input:~ # mdadm --assemble / dev / md2 / dev / sd [bcd] 3 - executemdadm: / dev / md2 was started with 3 drives (out of 4).At the second input I had the following result:~ # mdadm --assemble / dev / md2 / dev / sd [bcd] 3 - executemdadm: / dev / sdb3 is busy - skippedmdadm: / dev / sdc3 is busy - skippedmdadm: / dev / sdd3 is busy - skippedHere you can see the latest screenshots of the "Storage Manager".0
At this moment the data volume was back. Didn't it automagically show up in the volume list?
Can you try to mount the volume?
<div>su</div><div><br></div><div>mkdir -p /mnt/md2</div><div><br></div><div>mount /dev/md2 /mnt/md2</div>
- 588 USG FLEX H Series
- 477 News and Release
