NAS 326 mount network drive
Azza
Hello
on my old NSA325 I can share the whole disk...volume1. This possibility can´t see in the nas326. How do i make sharing the full disk in windows ?
Thank you very much.
#NAS_Jan_2019
Zyxel has the design only available on NSA325/NSA325 v2, so you can't find it and mount it.
You can only mount the folder which is under volume1 one by one.0 -
well thank you
I'm not happy, there is no way to do it ?
try this, but one limitation is after reboot, the setting will be gone and you need to do again the modify.
Here is the description:
use telnet or ssh to log in your NAS326, modify /etc/samba/smb.conf, add new setting as the same configuration as other shared folder, but remember the path should be "/i-data/xxxxxxx", then use the command " /etc/init.d/samba.sh restart"
Then you can see the shared folder through CIFS and able to mount it as network drive0
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
