NAS 540 has lost all data.
13»
  • Cha
    Cha Posts: 16  Freshman Member
    Unfortunately I could not mount the volume. Here is the result of the input:
    ~ # su
    BusyBox v1.19.4 (2017-05-26 16:43:23 CST) built-in shell (ash)
    Enter 'help' for a list of built-in commands.
    ~ # mkdir -p / mnt / md2
    ~ # mount / dev / md2 / mnt / md2
    mount: unknown filesystem type 'LVM2_member'
  • Cha
    I pressed the Create button, see page 4:
    Then I broke off the process.
    What do you think? If you finish the process and include the disk? Is the data accessible or permanently gone?
  • Mijzelf
    Mijzelf Posts: 2,960  Guru Member
    The raid array isn't the data filesystem yet, there is a logical volume group on it. Unfortunately I have not much experience with that. A google brought me this, which seems a usable step-through.
    If you are root, by executing su, you can skip the 'sudo'.
    If you finish the process to create a new volume, the data is gone for all practical purposes.
  • Cha
    This time I logged in with root immediately and then the command
    started.
    The result:
    login as: root
    root@10.0.0.120's password:
    Unfortunately it is the same.
  • Mijzelf
    You didn't read that page I pointed to, did you?
    In your case you can't mount the assembled raid array directly, because you have to mount (one of) the embedded logical volumes.
