Muty X Firewall?
Sam
Sam Posts: 8 image  Freshman Member
edited January 2019 in Multy WiFi System
I was told when using a static IP on my Fritzbox, the Firwall on the Fritzbox will be disabled.  Does the Multy X has a Firewall built in? If so how can I make adjustments?  I cannot find anything in the Mutly X App.  Thanks again for your help.
#MultyX_Jan_2019
  • Zyxel_Steven
    Zyxel_Steven Posts: 246 image  Zyxel Employee
    edited January 2019
    @Sam,
    In NAT (Standard) Mode [Router Mode], Multy X supports basic SPI/DoS firewall functions. This will be turned-on by default. Multy App cannot configure the firewall rule.
