NAS 540 has lost all data.
Unfortunately I could not mount the volume. Here is the result of the input:~ # suBusyBox v1.19.4 (2017-05-26 16:43:23 CST) built-in shell (ash)Enter 'help' for a list of built-in commands.~ # mkdir -p / mnt / md2~ # mount / dev / md2 / mnt / md2mount: unknown filesystem type 'LVM2_member'0
I pressed the Create button, see page 4:Then I broke off the process.What do you think? If you finish the process and include the disk? Is the data accessible or permanently gone?0
mount: unknown filesystem type 'LVM2_member'The raid array isn't the data filesystem yet, there is a logical volume group on it. Unfortunately I have not much experience with that. A google brought me this, which seems a usable step-through.If you are root, by executing su, you can skip the 'sudo'.What do you think? If you finish the process and include the disk? Is the data accessible or permanently gone?If you finish the process to create a new volume, the data is gone for all practical purposes.0
This time I logged in with root immediately and then the command
started.
The result:
login as: root
root@10.0.0.120's password:
Unfortunately it is the same.0 -
You didn't read that page I pointed to, did you?In your case you can't mount the assembled raid array directly, because you have to mount (one of) the embedded logical volumes.0
- 415 Beta Program
- 2.5K Nebula
- 152 Nebula Ideas
- 101 Nebula Status and Incidents
- 5.8K Security
- 296 USG FLEX H Series
- 281 Security Ideas
- 1.5K Switch
- 77 Switch Ideas
- 1.1K Wireless
- 42 Wireless Ideas
- 6.5K Consumer Product
- 254 Service & License
- 396 News and Release
- 85 Security Advisories
- 29 Education Center
- 3.6K FAQ
- 76 Security Highlight
