Multy Plus, disable WLAN by timer
Rotsch
By Access Control it‘s only possible to disabel a device access.
How can I disable the Admin WLAN, guest WLAN etc. by Timer / Profile?
#MultyPlus_Jan_2019
#MultyPlus_Jan_2019
@Rotsch,
Currently, Multy Plus cannot set a Timer/Profile to turn on/off WiFi.
It only can turn on/off WiFi by manual.
Can you share the purpose why you need this feature?0 -
Is a power and security part. All is not on, can not be hack and don‘t use power. All devices I can power off, I swtich them off and not let be on power save mode.0
@Rotsch,
Multy Plus is the WiFi system instead of a standalone router.
It is required to keep WiFi radio on so that different nodes of Multy units can keep connected as a whole system. Once it is shut, there is no way to turn extender node back. Because root node and extender node is used dedicated wireless backhaul to connect/communicate each other.0 -
No
If the WIFI not in use / using, it is not importent to be avelable the Multy units connection by WIFI. If it musst be on, I would not ask to be possible to disable the WIFI by schedule…. If I power off the Multy Units, I have the problem of none connection to the WAN for the LAN devices…..
- 588 USG FLEX H Series
- 477 News and Release
