No DSL connect with VMG1312-B30A
Andreas
if I connect a Fritz!Box to my DSL plug I get a connection with these information:
VDSL2 17a G.Vector (ITU G.993.5)
If I try the same with the VMG1312-B30A, using the same cables I do not get a connection at all. The Monitor shows xDSL state "Training" for a while and then it shows "Idle". I never get a conenction.
My firmware is 1.00 (AAEB.4)
I use the original configuration without any modifications (bridge mode)
Can anyone give me a hint what to do to connect the VMG1312-B30A successfully?
#CPE_Jan_2019
#CPE_Jan_2019
Hi Andreas,
Please refer to the below link for the user guide.
https://www.zyxel.com/support/DownloadLandingSR.shtml?c=gb&l=en&kbid=M-01086&md=VMG1312-B10A
You can find chapter 6 for WAN side connection setting, then check if your current setting can fulfill the environment.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
