NAS540 crashes due to high CPU load (python?)
A combined speed of 200mbit is huge. I suppose you are also seeding, in which case you are streaming 40MB in random blocks. At a blocksize of 512kB, that means 80 seek actions a second. A seek on a mechanical harddisk typically costs 20msec, so it's seeking 1600msec per second.No wonder something stalls. Although it shouldn't crash.0
Ok I can understand that but why is this happening after 5 years of never having the problem. I have a seed limit of 25kbps total so that won't be the issue I think.
Also why do I only have the problem with large files and not with smaller ones?
If it's crashed, does it still shutdown normally, when the power button is pressed? In that case Linux is still alive, and you could collect some post mortem info by using the 'intercept copy button' tweak.0
When it crashes I can't access anything remotely.
The lights on the NAS itself are still on. I didn't press any buttons yet.
What should I configure in the intercept copy button tweak?0 -
The first action which come to my mind is to dump the output of dmesg to a file on harddisk, to see if the kernel is aware the something is going on.
Can you explain how to do it to a noob like me?0
In the Tweaks webinterface tick 'Enable interception', and 'Beep on intercept' is useful too.Then, in 'Short press', put
<div>dmesg >"/i-data/sysvol/admin/\$(date).dmesg"<br></div>
After you press Apply, that will be changed in '...admin/$(date)...' (without the backslash). Don't press Apply twice, then $(date) will be resolved to the current date. That's a mild bug.When pressing the copy button, it will write a file 'current date'.dmesg on the admin share. (on release of the button).0
- 383 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 75 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 210 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 886 Nebula FAQ
- 415 Security FAQ
- 228 Switch FAQ
- 200 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
