How to update the NAS540 firmware from the serial terminal?
I still don't see a clear reason why the webserver isn't started. AFAIK it is not started directly or indirectly by /etc/init.d/rcS, and so it's hard to find reasons why it wouldn't start.Have you already tried a factory reset?0
That's the solution! The factory reset solved the problem.
For the sake of the completion of this question, I did not find a way to upgrade the firmware from the serial port but I was able to manage a full update to the latest FW.
Thank you for the support.
- 441 Beta Program
- 534 USG FLEX H Series
- 334 Security Ideas
- 51 Wireless Ideas
- 294 Service & License
- 461 News and Release
