How to update the NAS540 firmware from the serial terminal?
2»
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    I still don't see a clear reason why the webserver isn't started. AFAIK it is not started directly or indirectly by /etc/init.d/rcS, and so it's hard to find reasons why it wouldn't start.
    Have you already  tried a factory reset?
  • Matteo
    Matteo Posts: 9 image  Freshman Member
    That's the solution! The factory reset solved the problem.
    For the sake of the completion of this question, I did not find a way to upgrade the firmware from the serial port but I was able to manage a full update to the latest FW.
    Thank you for the support.
