What’s your VMG8825 firmware version?
Have you checked the Media Library Path? You may need to enter the current path for access.
Problems with media server on VMG8825-B50B
Tremors
On this router I connect a USB HDD with many media files (music, videos, pictures) and I'm currently sharing the folders without issues through the USB file sharing settings. I can see folders and all files as smb:\\ path on several devices within the network (i.e. Kodi on my TV Box).
If I activate the Media Server feature on the router, I can see it as available library on Windows Media Player, but the files that I can play are just the ones contained on the root path. All the mp3s divided and ordered by different folders per genre and artist are invisible.
The same happens when I access the media server on a network player.
Is anyone experiencing the same? How to fix this?
#CPE_Jan_2019
#CPE_Jan_2019
Hi Tremors,
Hi AAAAL.The firmware is V5.13(ABLZ.0)b10_20180319.I cannot change the path but the Media Server is visible on the WIndows Player, also the files on the root folder are visible anyway. I don't understand why the files included in the inner folders are not available (music, videos, etc.)
Hi Tremors,
Have you tried to add a path on your Windows Media Player?
If we create a library location in server side, those videos can be played or not?0 -
I tried to add the path to my music on the external hdd, but I get the following message:"The path has been added to the library, but it cannot be shared."0
Hi Tremors,
Is this a single case on your HDD? What’s the result with the other USB shared?
Hi Tremors, i've the same problem. Did you resolved it?
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
