WiFi Calling QoS setup VMG4825
dancingbrook
Hi all, I'm looking to improve my service a bit and hoping setting up QOS will help. Any advice and direction is appreciated.
1st, I want to prioritize AT&T wifi calling and other VOIP services. This doc explains the settings but I don't know how to implement.
2nd, I'd like to limit per device usage, perhaps to 50% of bandwidth, assuming others are on and need bandwidth as well. Is this possible on the VMG4825?
#CPE_Feb_2019
#CPE_Feb_2019
Hi there
For your 1st Q, I also checked the page of AT&T wifi calling, but it seems that you should have no problem to use AT&T wifi calling. VMG4825 seems not any limitations of using AT&T wifi calling.
IPSec pass-throug, certain ports, MTU and FQDN are all OK on VMG4825.
Did you meet any problem on AT&T wifi calling setup?
For the 2nd Q, VMG4825 supports the bandwidth limitation for per interfaces or SSID, but doesn't support to limit per device usage.
For your reference.
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
