Install TVHeadend on NAS326
Fusel
Fusel Posts: 6 image  Freshman Member
edited February 2019 in Personal Cloud Storage
Is it possible to install TVHeadend on NAS326 and hardware strong enough to use?
On https://synocommunity.com/package/tvheadend a package for armada38x is aviable.
Can I use this for NAS326 by using MetaRepository and how do I use own packages in MetaRepository?
Sry for bad english - main german
:smile:
#NAS_Feb_2019
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    To install it using MetaRepository it has to be repackaged as a ZyXEL package. Here you can find some documentation about how a ZyXEL package is made.
    But I remember a long thread on nas-central.org (which is down, unfortunately) which main conclusion was that getting the device drivers for the tuner working is a bigger problem than getting the binary running. And no, the Synology kernel modules won't fit on your 326.
  • Fusel
    Thank you!
    I will try to create/install the package.
    Device driver should't be a problem, i plan to use an AVM DVB-C adapter.
