Armor Z1 NBG6816 problem with wifi and android devices Play Store
grendy
Hi!
I'm having a strange problem with my router (ver V1.00(AAWB.10)C0). I have two totally different Android devices with different android versions and for a couple of months or so I haven't been able to update any of my Android apps with the wifi that's coming from my router. With mobile data and/or any other wifi updating apps isn't a problem.
My router is behing a cable modem (Arris TG2492s) device that's acting as an AP and should forward everything as is to the router. DHCP is being handled also by NBG6816.
These android devices and all other devices work perfectly otherwise and I can even browse Play store but just can't download apps or update them! I'm pretty sure that the problem is with the cable modem somehow but I'm just wondering if anyone has any idea what's causing this or is there some setting that I could just click that would fix this? Have tried rebooting both of the devices but wouldn't want to reset settings because everything else works and basically I can live with the problem but it's just really annoying and weird
#Router_Feb_2019
#Router_Feb_2019
@grendy,
In order to provide you with a better assistance, we have contacted you via private message. Please kindly check your message box.0 -
The problem is in the /sbin/update_lan_dns file.
Comment out this lines and reboot the router:
address=/clients3.google.com/192.168.1.1
address=/connectivitycheck.android.com/192.168.1.1
address=/connectivitycheck.gstatic.com/192.168.1.1
Hello, have the same problem as grendy.
How can i connect to the commadline to commend out this lines?
Thanks0 -
Sorry, but also I have the same problem0
problem is solved, I have received a firmware update from Zyxel and now everything is running properly, thank you
Cann not connect whit WinSCP and Protocol SCP0 -
I checked firmware update in the router, but no updates found.0
- 398 Beta Program
- 2.1K Nebula
- 117 Nebula Ideas
- 83 Nebula Status and Incidents
- 5.2K Security
- 99 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 922 WirelessLAN
- 35 WLAN Ideas
- 5.9K Consumer Product
- 212 Service & License
- 337 News and Release
- 71 Security Advisories
- 21 Education Center
- 2.1K FAQ
- 989 Nebula FAQ
- 445 Security FAQ
- 238 Switch FAQ
- 213 WirelessLAN FAQ
- 47 Consumer Product FAQ
- 140 Service & License FAQ
- 72 About Community
- 62 Security Highlight
