NAS540 - XenServer
jhonplanet
jhonplanet Posts: 2 image  Freshman Member
edited June 2019 in Personal Cloud Storage
Hi everyone
I have a Nas540 but i cant connect with a XenServer, I cant use iSCSI and NFS,
With iSCSI i cant to authentication
With HFS the Disk is Inactive
Can you help me please.
I use the last version
Thanks a lot
#NAS_Mar_2019
  • Ijnrsi
    Ijnrsi Posts: 254 image  Master Member
    why you can't authentication your iSCSI?
    NFS is inactive?
    how your to configure the NFS link on your device?
  • itslave
    itslave Posts: 3 image  Freshman Member
    Has anyone successfully connected their NAS with ISCSI to a XenServer?  Running into issue with CHAP authentication.
  • Batou
    Batou Posts: 101 image  Ally Member
    Is there any error message when connected NAS with ISCSI to a XenServer?
    Can you share some screenshots about this problem?
  • itslave
    CHAP authentication failed.
  • Mel
    Mel Posts: 83 image  Ally Member
    My NAS540 is working on Windows 10 (iSCSI), I suggest you can use it to replace XenServer.
  • Mijzelf
    Mijzelf Posts: 3,042 image  Guru Member
    <quote>CHAP authentication failed.</quote>
    If you search this forum for chap, you'll find a solution someone found. Sort of. When I understand it correctly, the trick is to switch off authentication completely.
