Armor Z2 signal loss
Solar
Dear all
#Router_Mar_2019
The problem : the router loses the signal for a short time. I checked all possible options - wan connection, updated the firmware, make ping test from the router and have - network is unreachable ! ...etc.\
I also tested the network on other routers and everything working well.
In the process of opersaion, the router randomly briefly loses the network for 1-2 sec - which is enough to hang the clients lan. the provaider sees my breaks and confirms that everything is ok from his side (I have log from provaider equipment from diferent routers from my side).
Network loss occurs in random order - this can be every 30 min or every 2-3 min.
Please help ^ this problem makes me crazy.
If you need additional info - just let me know.
Thank you
#Router_Mar_2019
I see nobody has responded yet, if anyone has any idea what's going on please let me know.
What is the firmware version and topology?
Is possible to share the setting about Internet Connection?
What do you mean loses the signal for a short time? Can you explain more detail?
LAN and WLAN device all will happen randomly briefly loses the network for 1-2 sec?
Do you try to back to factory defaults? Is it still the same?0 -
Model Number: NBG6817
Firmware Version: V1.00(ABCS.9)C0Sys OP Mode: Router ModeWAN connection lose signal and all LAN clients freez (if it is online game - you disconect)Yes it is - I cant find any rule - it happened randomlyI try to make ping test from the diferent routers (telnet) and all routers working without any problems but if you try to make test with Armor Z2 - you have problem - network is unreachable !!!also I have log from Armor - he lose connection at this time and connect againe after 2-3 sec (((You cant back to previuosly firmware versions cause router said - you have the latest versionRegarding back to defaults - Yes I try....
This is the log from the router:crash moment326 2019 Mar 24 20:23:06 daemon.info streamboost: StreamBoost: Executing start all327 2019 Mar 24 20:23:06 daemon.info streamboost: Event ifup
328 2019 Mar 24 20:22:57 daemon.notice netifd: Interface 'wan6in4' is now down
329 2019 Mar 24 20:22:57 daemon.notice netifd: Interface 'wan6to4' is now down
330 2019 Mar 24 20:22:57 daemon.notice netifd: Interface 'wan' is now up
331 2019 Mar 24 20:22:57 daemon.warn dnsmasq[8235]: no servers found in /tmp/resolv.conf.auto, will retry
332 2019 Mar 24 20:22:57 daemon.notice netifd: Interface 'wan' is now down
333 2019 Mar 24 20:22:54 daemon.warn miniupnpd[10141]: SendNATPMPPublicAddressChangeNotification: cannot get public IP address, stopping
334 2019 Mar 24 20:22:54 daemon.err miniupnpd[10141]: Failed to get IP for interface eth0
Is possible to provide more log information?
Do you use PPPoE or PPTP or IPoE? And do you set any IPv6 Tunneling (6RD/6to4/6in4)?0 -
Hi Hill,PPPoeno sets for IPv6
also I add log from my provaiderMar 24 19:16:09:LinkStatus-6:Port 4 link up, 1Gbps FULL duplex
499 Mar 24 19:16:03:LinkStatus-6:port 4 link down
498 Mar 24 19:14:43:LinkStatus-6:Port 4 link up, 1Gbps FULL duplex
497 Mar 24 19:14:40:LinkStatus-6:port 4 link down
496 Mar 24 19:14:36:LinkStatus-6:Port 4 link up, 1Gbps FULL duplex
495 Mar 24 19:14:33:LinkStatus-6:port 4 link down
494 Mar 24 19:14:14:LinkStatus-6:Port 4 link up, 1Gbps FULL duplex
493 Mar 24 19:14:11:LinkStatus-6:port 4 link down
492 Mar 24 19:14:04:LinkStatus-6:Port 4 link up, 1Gbps FULL duplex
491 Mar 24 19:14:01:LinkStatus-6:port 4 link down
490 Mar 24 19:13:41:LinkStatus-6:Port 4 link up, 1Gbps FULL duplex
489 Mar 24 19:13:38:LinkStatus-6:port 4 link down
487 Mar 24 19:08:08:LinkStatus-6:Port 4 link up, 1Gbps FULL duplex
@Solar,
In order to provide you with a better assistance, we have contacted you via private message. Please kindly check your message box. Thanks.
Hello Community,i just found this thread and wanted to ask if there is already a solution for this problem because i got exactly the same issues.looking forward reading from you. regards0
- 222 Nebula Ideas
- 617 USG FLEX H Series
- 53 Wireless Ideas
- 485 News and Release
