How do you change on multy x the ISP password so that the multy will connect to internet
Andzy19
How do you change on multy x which had already been set up with a new isp password so that it will connect to the internet
#MultyX_Mar_2019
#MultyX_Mar_2019
If you want to change any WAN setting, you need to reset and reinstall Multy X WiFi System.
You can check below discussion link.
https://homeforum.zyxel.com/discussion/1432/how-do-i-change-the-pppoe-settings-within-my-multy-x-setup-without-deleting-an-entire-multy-x-site
Thank you for the update and link, this would be a much needed setting for the Multy to have in any future updates.1
- 588 USG FLEX H Series
- 477 News and Release
