Is it possible to use the PLA4231 as an adapter?
Langerhans
I bought two PLA4231 extenders by mistake, instead of one PLA4231 extender and one PLA4201 adapter. Could use the second PLA4231 extender as a PLA4201 adapter?
#PLA_Mar_2019
#PLA_Mar_2019
Do you want to use PLA4231 and PLA4201 together? Or ...?
In my house, they can work together. I'm use them.
Router's LAN is connected to PLA4231, and PLA4231 is paired with PLA4201.
My laptop is connected to PLA4201 via Ethernet cable, it works properly.0 -
Hi Edward. No. I bought two PLA4231 by mistake instead og one PLA4231 and one PLA4201.0
Two PLA4231 can be worked together.
Can you describe more clear what kind of problem you meet?
- 439 Beta Program
- 2.8K Nebula
- 200 Nebula Ideas
- 6.3K Security
- 500 USG FLEX H Series
- 323 Security Ideas
- 49 Wireless Ideas
- 287 Service & License
- 457 News and Release
- 89 Security Advisories
- 4.3K FAQ
- 96 Security Highlight
