Armor Z2 signal loss
Hi, I just started using my Armor Z2 again after my other router died, and I'm also having the LAN dropouts. I have the V1.00(ABCS.9)C0 firmware from December. Is that the latest firmware? Thanks.
WastedYouth,
Yes, V1.00(ABCS.9)C0 is the latest official firmware version.
Can you explain more information about the LAN dropouts problem? Has any screenshots?
What is your network topology? Do you try to disable "StreamBoost" on Armor Z2?0 -
I'm having exactly the same issue.
Should i disable streamboost ? Is streamboost causing the issues with the daemon service failing or is something else ?12 2019 Nov 30 22:58:19 daemon.warn miniupnpd[7282]: SSDP packet sender 223.254.253.251:1900 not from a LAN, ignoring 13 2019 Nov 30 22:58:19 daemon.warn miniupnpd[7282]: SSDP packet sender 223.254.253.251:1900 not from a LAN, ignoring 14 2019 Nov 30 22:58:19 daemon.warn miniupnpd[7282]: SSDP packet sender 223.254.253.251:1900 not from a LAN, ignoring 15 2019 Nov 30 22:58:19 daemon.warn miniupnpd[7282]: SSDP packet sender 223.254.253.251:1900 not from a LAN, ignoring 16 2019 Nov 30 22:58:19 daemon.warn miniupnpd[7282]: SSDP packet sender 223.254.253.251:1900 not from a LAN, ignoring 17 2019 Nov 30 22:58:19 daemon.warn miniupnpd[7282]: SSDP packet sender 223.254.253.251:1900 not from a LAN, ignoring 18 2019 Nov 30 22:58:19 daemon.warn miniupnpd[7282]: SSDP packet sender 223.254.253.251:1900 not from a LAN, ignoring 19 2019 Nov 30 22:58:19 daemon.warn miniupnpd[7282]: SSDP packet sender 223.254.253.251:1900 not from a LAN, ignoring 20 2019 Nov 30 22:58:19 daemon.warn miniupnpd[7282]: SSDP packet sender 223.254.253.251:1900 not from a LAN, ignoring 21 2019 Nov 30 22:58:19 daemon.warn miniupnpd[7282]: SSDP packet sender 223.254.253.251:1900 not from a LAN, ignoring 22 2019 Nov 30 22:58:19 daemon.warn miniupnpd[7282]: SSDP packet sender 223.254.253.251:1900 not from a LAN, ignoring 23 2019 Nov 30 22:58:19 daemon.warn miniupnpd[7282]: SSDP packet sender 223.254.253.251:1900 not from a LAN, ignoring 24 2019 Nov 30 22:58:19 daemon.warn miniupnpd[7282]: SSDP packet sender 223.254.253.251:1900 not from a LAN, ignoring 25 2019 Nov 30 22:58:18 daemon.warn miniupnpd[7282]: SSDP packet sender 223.254.253.251:1900 not from a LAN, ignoring 26 2019 Nov 30 22:58:18 daemon.warn miniupnpd[7282]: SSDP packet sender 223.254.253.251:1900 not from a LAN, ignoring 27 2019 Nov 30 22:58:18 daemon.warn miniupnpd[7282]: SSDP packet sender 223.254.253.251:1900 not from a LAN, ignoring 28 2019 Nov 30 22:58:18 daemon.warn miniupnpd[7282]: SSDP packet sender 223.254.253.251:1900 not from a LAN, ignoring 29 2019 Nov 30 22:58:18 daemon.warn miniupnpd[7282]: SSDP packet sender 223.254.253.251:1900 not from a LAN, ignoring 0
- 215 Nebula Ideas
- 568 USG FLEX H Series
- 342 Security Ideas
- 295 Service & License
- 471 News and Release
