reset button on VMG4825-B10A
AFD
Was changing to a more secure username/pw and was interrupted. Lost the new ones that were saved. IF I use the reset button on the router could I lose my credentials/settings to my ISP (consolidated.com)? I don't want to do that. Just get back to admin/1234.
#CPE_Feb_2019
#CPE_Feb_2019
Hi
As I know, the router normally has customized default configuration if it came from an ISP.
So, I think you should still has the ISP default setting after you press reset button.
But I still suggest you double checked with consolidated if these is a consolidated default configuration on your router.
I just reset my router, and the new password I had set up did not go back to the original password that is printed on the side of the router.0
how long did you press the reset button?
It needs to press the reset button more than 10 seconds to reset the router to default setting.0 -
As I read You want to ask that, change more secure username/password is a problem or not/
So I must say your more secure username/ password is never your problem. You have to just turn off your router for some time then check your new username/password working or not. Because the same thing happen to me last Sunday and this was rectified via doing this
Hope this will help you
Thanks0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
