Sonos and Multy X
andreasga
Hi all,
i have a Sonos system with a Multy X mesh. Unfortunatly i cant get a PLAY 1 Loudspeker connected to the third Multy. It works fine with the main Multy X, but If I want to connect it to the third it failed always. Any ideas??
#MultyX_Apr_2019
#MultyX_Apr_2019
Here are some questions to clarify.
.What is the LED status of 3rd node?
.Can other device connect to 3rd node?
.Do you try to reset Sonos PLAY:1?
.What do you mean when connect it to the third it failed always? What kind of symptom?
.Do you use wireless or wired of Sonos PLAY:1 to connect 3rd node? If wireless not works, please try to use wired.
- 220 Nebula Ideas
- 606 USG FLEX H Series
- 482 News and Release
