NAS542 replace disks.
Boyanski
Hello guys, I'm planning to upgrade my NAS with new disks. I have ordered four equal size WD Reds, which I'd like to configure in Raid 10. Right now I have two different disks, that are standalone (Basic), where most of my data is, and another two 300 GB, which I've configured in Raid 1 and as an iSCSI drive. I'll ditch the iSCSI now and use only shares.
What should I do before removing the current disks? If I turn off the NAS, remove them, install the new ones, turn on, create the Raid 10 partition and the shares, is this enough? Then I can connect the old disks through eSATA and copy the data to the NAS, right? I guess I should remove the iSCSI from windows.
Any advise and recommendations if I'm missing something?
Thanks!
#NAS_Apr_2019
Thanks!
#NAS_Apr_2019
Best Answers
To create a new volume it's enough to pull the current disks, insert the new ones and create a volume. But reading the old disks is not that easy. The NAS doesn't have esata ports, so I assume you want to use some other box. It has to run Linux, to be able to assemble and mount the basic volume. Don't know about the iSCSI. AFAIK that is from the NAS point of view an ordinary file, which is served as disk on the network. Don't know if that can easily be mounted.
Yes, that are the right commands. Except that you'll also have to
<div>mkdir -p /mnt/test</div>
Yes, I will connect them to my PC's esata locally. The iSCSI is small, I have backuped to the single drives. I was wondering if the system would alarm that its missing. I guess not.
Thank you for your answer!0 -
I connected the disk with esata but it looks like its not ext4 or similar file system. I says "linux raid member". Is it possible to mount it and read it?
I have found some commands, will they work, I don't want to loose my data?$ mdadm --assemble --run /dev/md0 /dev/sdc3 $ mount /dev/md0 /mnt/test
- 588 USG FLEX H Series
- 477 News and Release
