NSA 325 - internal volume down - No such file or directory: '/i-data/md0/.system'
RualM
Yesterday there was a blackout, and now the NAS has a problem. Intrenal volume is down, and in the log I've got an interesting message
- Cannot init applets: [Errno 2] No such file or directory: '/i-data/md0/.system'
A grab a picture from its current state. Is there any option to restore the NAS?
The "No md superblock detected on /dev/sda1/" message is normal?
Thanks in advance,
RualM
#NAS_May_2019
Thanks in advance,
RualM
#NAS_May_2019
The raid array is obviously assembled, but it's not mounted. So you have probably a damaged filesystem. The most straightforward solution is to repair it:
e2fsck /dev/md0
hi,
Sorry, I'm totally rookie in this... I've typed, but~ # e2fsck /dev/md0-sh: e2fsck: not found~ #0 -
Hm. For some reason ZyXEL decided to rename it to e2fsck.new
Nice...
Results below. Internal volume still in down
~ # e2fsck.new /dev/md0e2fsck 1.41.14 (22-Dec-2010)/dev/md0: recovering journal/dev/md0 has been mounted 118 times without being checked, check forced.Pass 1: Checking inodes, blocks, and sizesPass 2: Checking directory structurePass 3: Checking directory connectivityPass 4: Checking reference countsPass 5: Checking group summary information/dev/md0: ***** FILE SYSTEM WAS MODIFIED *****/dev/md0: 121464/122068992 files (5.1% non-contiguous), 461498180/488249472 blocks0 -
Have you rebooted?
Yes, it was restarted. Both the log message and the symptom are the same
Try to mount it manually.
<div>mkdir /mnt/mountpoint</div><div><br></div><div>mount /dev/md0 /mnt/mountpoint</div><div></div>
If that errors out, have a look at the kernel messagesdmesg | tail
There weren't errors, but no changes after restart.
Does the below is usable for further investigation?~ # dmesg | tailxHCI xhci_check_bandwidth called for root hubhub 2-0:1.0: USB hub foundhub 2-0:1.0: 4 ports detectedAdding 514040k swap on /dev/sda1. Priority:-1 extents:1 across:514040kGbE port 0: TxEnable WA - Enabled, deep=1, tx_en_bk=1Uncached vma de8b1288 (addr 40ad1000 flags 080000ff phy 1edcb000) from pid 2767Uncached vma de8b11d8 (addr 40ad4000 flags 080000ff phy 1edcb000) from pid 2767Uncached vma de8b11d8 (addr 40651000 flags 080000ff phy 1edcb000) from pid 1371Uncached vma de8b11d8 (addr 40651000 flags 080000ff phy 1edcb000) from pid 13710 -
I repeated the process, and after the mount I got a littlebit different messages:~ # mkdir /mnt/mountpoint~ # mount /dev/md0 /mnt/mountpoint~ # dmesg | tailUncached vma de8b11d8 (addr 40ad4000 flags 080000ff phy 1edcb000) from pid 2767Uncached vma de8b11d8 (addr 40651000 flags 080000ff phy 1edcb000) from pid 1371Uncached vma de8b11d8 (addr 40651000 flags 080000ff phy 1edcb000) from pid 1371EXT4-fs (md0): barriers enabledkjournald2 starting: pid 3666, dev md0:8, commit interval 5 secondsEXT4-fs (md0): internal journal on md0:8EXT4-fs (md0): delayed allocation enabledEXT4-fs: file extents enabledEXT4-fs: mballoc enabledEXT4-fs (md0): mounted filesystem with ordered data mode~ #0
Hmm, interesting... I removed one the disks, and now the state is degraded... I found the faulty disk.
Do I have to delete the faulty volume, and after that try to rebuild the raid, as a newly inserted disk?0
- 588 USG FLEX H Series
- 477 News and Release
