NSA 325 - internal volume down - No such file or directory: '/i-data/md0/.system'
2»
  • RualM
    RualM Posts: 9 image  Freshman Member
    Well, I've started the actions above, and now it's in recovering status  :)
    I think all of your advices were missing from my toolbox.... Thank you!
  • Mijzelf
    Mijzelf Posts: 3,049 image  Guru Member
    We'll see when recovering is done. Theoretically the raid manager is independent from the volume manager. You had an valid raid array /dev/md0, and you pulled a disk. Then the array is degraded, but that doesn't affect the volume on it. Because raid1. The array can recover without knowledge of the filesystem inside. That's why it lasts that long, all sectors are copied, no matter if they are in use or not. The raid system doesn't know.
    The kernel messages after the mount look normal. Just a succeeded attempt to mount a valid ext4 filesystem. (Except for the 'Uncached vma' messages. Don't know what that are. I have them too, and they seem harmless.)
  • RualM
    Recovery has been finished, everything is ok. Thanks again for your help! :)
