I don't seem able to use my NAS any more
Rowan
I have an NSA310, with a 4TB disk attached via USB. The original disk of the NAS is completely full, the add-on disk is about 50% full. I need to create some new folders on the add-on disk, but when I try to do this via Windows Explorer, it says "you need permission to perform this action" and won't let me proceed. I am using Windows 8.1. How do I get it to allow me to modify the folder structure of the disk, and copy new files to it?
Thanks - Rowan
#NAS_Apr_2019
Thanks - Rowan
#NAS_Apr_2019
Have you previously been able to create directories on that disk, using the NAS?
Can't be 100% sure, but I think so, yes.
Rowan0 -
Today when I try to access the NAS (which appears with its name NSA310 in Windows Explorer) it says:[Window Title]Network Error[Main Instruction]Windows cannot access \\NSA310[Content]You do not have permission to access \\NSA310. Contact your network administrator to request access.For more information about permissions, see Windows Help and Support[Close]
How do I get to be able to connect to the NAS from Windows Explorer?
How do I attempt to give a different username and password for the connection?
Recent versions of Windows seem to have become so paranoid about security that they are more or less unusable. I do not have a security problem, as far as I know. My computers are on a small LAN, with only two users (my wife and myself). No-one is going to try to hack into my PC, or my wife's, unless someone can get in through my internet modem/router. For me, it would be better to go back to a much simpler security model that allows me (as admin) to access anything at all.
Thanks - Rowan0 -
It's some time ago I used Windows (and never used Windows 8+). On W7 you could logout from all network stuff from the command prompt:
net session /DELETE
Even i had similar issues while accessing my NAS good questions .0
- 164 Beta Program
- 1.7K Nebula
- 86 Nebula Ideas
- 4.7K Security
- 236 Security Ideas
- 1.1K Switch
- 50 Switch Ideas
- 908 WirelessLAN
- 27 WLAN Ideas
- 5.3K Consumer Product
- 172 Service & License
- 294 News and Release
- 65 Security Advisories
- 14 Education Center
- 911 FAQ
- 399 Nebula FAQ
- 249 Security FAQ
- 90 Switch FAQ
- 100 WirelessLAN FAQ
- 18 Consumer Product FAQ
- 55 Service & License FAQ
- 68 About Community
- 51 Security Highlight
FAQ
