Port Forward
Hayne
Im using a BT smart hub 6 on infinity with the wireless turned off as my modem. Multi network is set up and working fine. How do I port forward my CCTV DVR through the modem (smart hub) when it’s connected to a multi box as when I try to set up a port forwarding rule the smart hub won’t accept the up address of the DVD as the multi wan is xxx.xxx.212.x and the smart hub is xxx.xxx.1.x
i don’t want to go back and reset up the entire multi network using the home hub wan address criteria if there is another way.
With the CCTV plugged into the smart hub wan and port forwarding set up on the smart hub it works fine, but I really want to plug in the CCTV to a multi x box as it will avoid running long cables.
any ideas?
#MultyX_May_2019
any ideas?
#MultyX_May_2019
So you have 2 cascaded routers, and want to access one of the devices in the inner network from outside?You'll have to forward the right port in the outer router to the WAN address of the inner router, and then forward that port in the inner router to the device.0
If you want to connect CCTV DVR on Multy, maybe you can change CCTV DVR's IP address as 192.168.212.X, or change Multy as bridge mode, then set port forward rule on BT smart hub 6.0
If I change the cctv IP address away from the BT hub then the hub won’t allow a port forward rule to that “unknown” address. That’s the problem.0
Please share your port forward setting.
I suggest you to set Multy X as bridge mode. If Multy X is router mode, you may need to configure port forward rule on BT smart hub 6 and Multy X.
- 237 Nebula Ideas
- 6.8K Security
- 746 USG FLEX H Series
- 377 Security Ideas
- 58 Wireless Ideas
- 7.2K Consumer Product
- 319 Service & License
- 512 News and Release
- 99 Security Advisories
- 5.3K FAQ
- 90 About Community
- 119 Security Highlight
