Wipe disk on NAS 326
Barrie
Barrie Posts: 2 image  Freshman Member
edited May 2019 in Personal Cloud Storage
I tried to upgrade my NAS 325 from 2off 2TB (RAID 1) to 2off 4TB but it did not work, so I have ended up with two 4TB disks that have valid linux_raid_numbers. I have now purchased a NAS 326 and want to try again. However, since the 4TB disks have valid linux_raid_numbers I want to wipe them before trying to transfer the data from the 2TB disks. If I install a 4TB disk in the NAS 326 and SSH to it, fdisk tells me "/dev/sda2: device contains a valid 'linux_raid_member' signature, it's strongly recommended to wipe the device by command wipefs(8) if this setup is unexpected to avoid possible collisions.". Unfortunately BusyBox does not have the wipefs command. So, how can I wipe the disks?
#NAS_May_2019
  • Barrie
    When you boot up the NAS with a disk in it, it asks you if you want to wipe the disk.
  • Mijzelf
    Mijzelf Posts: 3,047 image  Guru Member
    Does that solve your problem, or am I misunderstanding you?
