nas326
crocket
crocket Posts: 1 image  Freshman Member
edited May 2019 in Personal Cloud Storage
Hello, I have a big problem with my nas326. In the configuration web portal, i have changed the metod of connection to the web portal login, from http to https, only in https mode.
After that isn't possible to connect to my nas, https://nas326/ is not ok, but also http://nas326 !!
Can you help me ??? I tried also to reset my password, but is the same,
#NAS_May_2019
  • ruivo1973
    ruivo1973 Posts: 5 image  Freshman Member
    same trouble too, only can use http!
  • Mijzelf
    Mijzelf Posts: 3,038 image  Guru Member
    Can't you access over https because your browser is whining about invalid certificates? In that case you'll have to push the 'I know the risks, let me in!' button, or your browsers equivalent. If your browser doesn't have that button, try another one. Firefox has one, it's called 'Advanced...'.
