VMG3625-T20A wont bridge
teksi
teksi Posts: 3 image  Freshman Member
edited May 2019 in Smart Home Product
Hello! I am trying to bridge my ZyXel VMG3625-T20A, but it just keeps "Loading..." I already spoke to service provider, and they said I should get in touch with you guys.
So the problem is I cant bridge my port number 4, because it just shows that "Loading..." screen and wont go anywhere from there. I already waited 40minutes two times.
Also I prefer finnish, but english will do also
#SP_May_2019
  • teksi
    I tried with Con-Current WAN bridge thing.
  • Hikari
    Hikari Posts: 99 image  Ally Member
    Hi teksi
    Do you mean you already have a WAN interface using routing mode, then you need another bridge WAN with same VLAN setting, thus you set up as concurrent WAN. And you were stuck in the con-current WAN configure page?
    May I ask which FW version you are testing with?
  • teksi
    @Hikari
    Yeah I'm stuck at con-current WAN configure page. When I select "port 4" and press "okay" it will show "loading..."screen, and wont go anywhere from there.
    Also "Current Firmware Version:V5.30(ABIE.3)b2_E0"
  • Zyxel_Support_CPE
    Zyxel_Support_CPE Posts: 188 image  Zyxel Employee
    Sixth Anniversary
    Hi teksi ,
    Yes, we aware of this issue from your ISP. Now we are clarifying it. If have any update, we will inform you/ISP.
