Plex.TV for NAS326??
  • Mijzelf
    Mijzelf Posts: 3,077
    image  Guru Member
    can I update?
    Sure. The version you have installed now is just another random version.
  • Nico
    Nico Posts: 9
    Friend Collector First Anniversary
    image  Freshman Member
    I've downloaded the file .spk.   and now? where have I put the file to proceed to the update?
  • Mijzelf
    image  Guru Member
    You can upload it in the same webinterface as you initially installed it. If you disabled that webpage, you can dis- and enable Plex in the packages menu to get it back.
  • Nico
    Nico Posts: 9
    TVM
  • emau74
    emau74 Posts: 53
    Friend Collector Third Anniversary
    image  Ally Member
    I don't understand where I'm wrong; I uploaded the web_prefix file in the admin folder
    I go to "all app" I update but I see nothing new;
    who helps me?
  • Mijzelf
    image  Guru Member
    The web_prefix file must not be uploaded to the admin folder, but to admin/zy-pkgs.
  • emau74
    emau74 Posts: 53
    image  Ally Member
    but for the NAS326 the zy-pkgs directory does not exist, in fact the guide says to put the file in admin
  • Mijzelf
    image  Guru Member
    From the README:
    How to install
    Step 1
    Download the file web_prefix, and put it in the directory \\<NAS>\admin\zy-pkgs\ on the NAS. Make sure your browser doesn't add any extensions to the file. The filename is web_prefix, without extension, all lowercase characters.
    NAS5xx, NAS326
    (Firmware 5.10+ only) On this NAS there is no subdirectory zy-pkgs in \\<NAS>\admin\. Just add it.
  • emau74
    emau74 Posts: 53
    image  Ally Member
    in fact I that a NAS326 ...
    "On this NAS there is no subdirectory zy-pkgs in a <NAS> admin
    so what should I do?
  • Mijzelf
    image  Guru Member
    Just add it.
