Firmware update problem
ZyxelRichard
ZyxelRichard Posts: 3 image  Freshman Member
First Anniversary
edited June 2019 in Multy WiFi System
Yesterday, I updated via my iphone app to firmware version V2.10(ABKJ.8)C0. I have two nodes but only the primary node has updated. The secondary node is still at V2.10(ABKJ.7)C0. I have switched both nodes off and on but they do not sync. Can anyone help?
#MultyX_Jun_2019
  • JamesL
    JamesL Posts: 38 image  Freshman Member
    edited June 2019
    What is the distance between the root node and the node 2?
    You can try to move the node 2 close to the root node, and reboot the node 2, see this is any improvement.
