3rd party packages, nas-central mirror
MrDini
Hi everyone,
Since downloads.nas-central.org has been down for a long time, and I wanted to install a few packages made by the users from there regardless I put up a mirror website here: [Click me]. Maybe someone will find it useful.
And the whole wget made mirror from January, 2019 is also available in a compressed archive here.
It should work as a remote repository for ffp and MetaRepo too however I had to setup some strict rate-limits in order to avoid the abuse. Currently it's 1 simultaneous connection per IP and 2 MB/s because my small server has a bad uplink. Let me know if you would like to have more bw.
#NAS_Jun_2019
#NAS_Jun_2019
Hi MrDini. Nice to see you back. Thanks for the mirror.
For my repo there's another mirror at http://zyxel.diskstation.eu/Users/Mijzelf/zypkg-repo/, which contains some newer packages.
Amazing! May I clone those and merge the new packages together with the backup?0
Sure.
Can I just add the URL above to Metarepositories page?
Or is there another way to change URL?
Thanks!0 -
You can add any directory, or url to an directory, which contains a ZYPKGS or ZYPKG_INFO.tgz file to let MetaRepository find it.
It should work, yes.
Thanks!!0
Hi MrDini, thanks very much for this. I have updated openssl to the latest version so I had to update many packages that depended on it and the data you posted helped me a lot.1
Yeah, absolutely fine. That's why I made the mirror.
Thanks for your work on this certainly makes it easier to find ffp packages rather than archive.org. Thanks for updating slacker to work with https repo's too
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 632 USG FLEX H Series
- 354 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 300 Service & License
- 492 News and Release
- 109 Security Highlight
