NAS540 Volume down ...need help
News from the nas. With
mdadm --create....
the nas didn´t start a recovery. The Partition sdb1..3 were los.Recovery? The idea is to rebuild a degraded md2. If that is done, and the filesystem is OK, you can let the firmware add the 4th disk.The whole idea of a 4 disk raid5 is that it can also run with 3 disks.Leave sdb until you can see your data.fdisk says, bad partition table backup at sdb and work with primary table...The disk has a GUID partition table, which is supposed to have a 2nd copy at the end of the disk.
- 588 USG FLEX H Series
- 476 News and Release
