AMG1302-T10B Portforwarding
Nova1
Posts: 3 Freshman Member
Hello, I have installed a cctv DVR, and I need to forward port 8240 to it to allow remote viewing of cameras on my phone, The DVR is on the same network as the Zyxel AMG1302-T10B and can be viewed on a web browser using its ipv4 address, the problem i am having is when I add a new rule under Service Define and I give my new rule the name cctv, then I enter in the External Start and External End ports number 8240 , then I enter the DVR ipv4 address into server address , and select protocol All, and enter 8240 into Open start and End ports The router replies back with 192.168.1.1 says Port range error! (1-65535) My port is with in this range so whats going on?
#SP_Jun_2019
#SP_Jun_2019
Hi Again all is well now up and running 100%. The fault was indeed the Firmware needed updated. Thanks for your help.0
Hi Nova
AMG1302-T10B is a really old model! I have tried on my side but no issue so far. Could you please let me know the FW version? and add a picture of how you set up the rule?0 -
Thanks for your reply, The firmware version I dont know but Im guessing it hasnt been updated since the ISP supplied the router, I have attached picture of the fault. I would of thought that portforwarding would be allowed regardless of the firmware version as it would be a basic function of any router?0
Hi Nova
I noticed !!! you have not config "Open Start/End port" !!
This GUI configuration will do direction from outside traffic port (external start/end port) forward to inside (Open Start/end) Port. Some customer may use a different port number, thus we separate external and internal port as a different column.
I could have an same issue result if I did not config "open start/end port". Please help to do another try. hope you can success this time0
- 383 Beta Program
- 2.1K Nebula
- 116 Nebula Ideas
- 80 Nebula Status and Incidents
- 5.1K Security
- 76 USG FLEX H Series
- 247 Security Ideas
- 1.3K Switch
- 69 Switch Ideas
- 907 WirelessLAN
- 34 WLAN Ideas
- 5.9K Consumer Product
- 209 Service & License
- 335 News and Release
- 71 Security Advisories
- 21 Education Center
- 1.9K FAQ
- 890 Nebula FAQ
- 415 Security FAQ
- 233 Switch FAQ
- 203 WirelessLAN FAQ
- 46 Consumer Product FAQ
- 137 Service & License FAQ
- 73 About Community
- 62 Security Highlight
