NSA325 "lost" Music and Video Folders
Lock
Lock Posts: 4 image  Freshman Member
edited June 2019 in Personal Cloud Storage
I have a NSA325 v1 with most recent firmware.  I was using my tv to watch a video and noticed it was not available.  Upon further investigation I noticed the only shared folder available to me was the "photos" folder.  I have looked to make sure that twonky was turned on and that the folders are published and they are.  I can access the folder with my laptop, but none of my media players on the tvs can see them.  I contacted support and was advised that the device was "no longer supported" and that the only thing they could advise was to reset it.  Which I did with no improvement.  I refreshed the TWONKY service and can see that it is only pulling files from the "photos" folder.  This just happened a few weeks ago after years of flawless service so I am not sure what caused it.  I also noticed the below article and wondered if this is the issue.
https://support.zyxel.eu/hc/en-us/articles/360000661479
Any suggestions?  Thanks in advance
#NAS_Jun_2019
Best Answers
  • Batou
    Batou Posts: 101 image  Ally Member
    Do you try to the workaround of that link?
    You also can check my previous post.
    https://homeforum.zyxel.com/discussion/2546/nsa325-lost-music-folders/p1
    - If you used CIFS (\\NAS_IP), is it able to see/access the folder/file?
    - If you used Windows Media Player, is it able to see/access the folder/file?
    - What is the setting of "Share Publish"?
    - What is the current firmware version of your NSA325v1?
  • Lock
    ·         No.  I have not attempted this yet as I have not had a great deal of experience with Linux.  I was hoping there might be an alternative
    ·         I have not used CIFS
    ·         Windows 10 Window Media Player does not see either the Video or Music folders.  It does see the photos folder.
    ·         See attached
    ·         NSA325_4.81(AAAJ.1)
  • Batou
    Try to use these option of Twonky web interface to see if there is any improvement.
    If not, you may need to try that link's workaround.
  • Lock
    Restart/Rescan/Clear Cache did not work at all.  The previous workaround does work, however, it is a bit more complicated for the 325v1.  It does not have SSH installed, but I stumbled across the below article on how to install it on the 320 and it worked.
    https://blog.julianxhokaxhiu.com/en/how-to-setup-an-ssh-server-on-zyxel-nsa320/
  • Lock
    edited June 2019 Answer ✓
    repost
