VMG - USB sharing BUG
parmi
I connected to my Zyxel Home & Life HUB (V5.13 (ABLZ.1) b8_20190225) a 6TB hard disk with 3 NTFS partitions.
The Zyxel correctly sees all three partitions, but allows only one partition to be shared.
I tried to share folders via SSH commands:
cfg usb_filesharing add --HostName usb1_sda1 --FolderName . --Description 'FirstPartition' --Public 1 Max is 20, current array length is 0 Command Successful.
cfg usb_filesharing add --HostName usb1_sda2 --FolderName . --Description 'SecondPartition' --Public 1 msg: X_ZYXEL_FolderName is duplicate. zcfgFeDalHandler return Fail! Command Successful.
#SP_Jun_2019
Hi parmi,It’s a known issue with (V5.13 (ABLZ.1) b8_20190225) fw for Zyxel Home & Life HUB and then we will fix in future.0
- 3K Nebula
- 223 Nebula Ideas
- 6.6K Security
- 628 USG FLEX H Series
- 353 Security Ideas
- 85 Switch Ideas
- 54 Wireless Ideas
- 299 Service & License
- 492 News and Release
- 108 Security Highlight
