NAS540 - XenServer
jhonplanet
Hi everyone
I have a Nas540 but i cant connect with a XenServer, I cant use iSCSI and NFS,
With iSCSI i cant to authentication
With HFS the Disk is Inactive
Can you help me please.
I use the last version
Thanks a lot
#NAS_Mar_2019
Thanks a lot
#NAS_Mar_2019
why you can't authentication your iSCSI?
NFS is inactive?
how your to configure the NFS link on your device?0 -
Has anyone successfully connected their NAS with ISCSI to a XenServer? Running into issue with CHAP authentication.0
Is there any error message when connected NAS with ISCSI to a XenServer?
Can you share some screenshots about this problem?0 -
CHAP authentication failed.0
My NAS540 is working on Windows 10 (iSCSI), I suggest you can use it to replace XenServer.
<quote>CHAP authentication failed.</quote>If you search this forum for chap, you'll find a solution someone found. Sort of. When I understand it correctly, the trick is to switch off authentication completely.
- 220 Nebula Ideas
- 608 USG FLEX H Series
- 299 Service & License
- 482 News and Release
