VMG3925-B10B - CHROMECAST TROUBLE
Bobobear
Hi, my router is a Zyxel VMG3925-B10B (Post Office), I just set up my new Google Chromecast but it can't be found. I should try and disable Access Point/AP isolation, but I could not find it in any menu (there is a Guest/More AP menu but all the guests were already disabled).
Do you have any idea on how I could make it work guys?
Thank you!
#SP_Jul_2019
#SP_Jul_2019
Hi Bobobear,
You mean you cannot find router SSID when trying to set up the connection between VMG3925 and Chromecast? May I ask if you're using which version Chromecast, 1 or 2 or 3? and router's FW ID? We have provided several FW version to POST Office customer, so I would need your FW version to do further check. Thank you.0
- 435 Beta Program
- 176 Nebula Ideas
- 428 USG FLEX H Series
- 298 Security Ideas
- 79 Switch Ideas
- 274 Service & License
- 422 News and Release
- 89 Security Highlight
