how to flash zyxel router p 660 hnu t1
gmlkhdr
gmlkhdr Posts: 1 image  Freshman Member
edited July 2019 in Smart Home Product
how to flash router with firmware I have already from zyxel support
#SP_Jul_2019
  • Hikari
    Hikari Posts: 99 image  Ally Member
    Hi gmlkhdr
    Do you mean you have a new FW received from Zyxel support and want to upload a new FW to the router?
    If yes, can you access the GUI now? If you are not sure the password please long press the factory reset button and you should be able to login device with the default password, then upgrade FW via GUI page.
